Intermittent no start condition
83,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
FLISSHAWK
Full power to all systems. When trying to start, all systems come on, but nothing happens. Starter does not attempt to engage, no clicking, nothing. Or vehicle starts normally. Suspect neutral safety switch, but am unable to find correct info for this particular model online.
Jun 10, 2022 at 3:30 AM
SQM
  • 6,383 POSTS
So, in an event of no start, what do you have to do to get it started?
Do you have to wiggle the shift lever back and forth?
Or if you try a few more times to start, it will start up without input to the shift lever?
If you have to move the shift lever back and forth to start, it could be the neutral safety switch.
https://www.2carpros.com/articles/how-a-neutral-safety-switch-works
Another possibility is a faulty ignition switch that has worn components.
Let me know of any questions.
Jun 10, 2022 at 6:03 AM
