Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Cavalier
Drivetrain
Transmission
Gear Position Sensor
Replace/Remove
Neutral safety switch removal
1998 CHEVROLET CAVALIER
146,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CELAWSON53
MEMBER
Having a problem removing neutral safety switch.
Nov 2, 2019 at 9:35 AM
Experienced Mechanic
Good evening,
Remove the 15mm nut on the shift linkage and then the connectors for the neutral switch. Remove the attaching screws and lift it up and off.
Image (Click to enlarge)
Nov 2, 2019 at 9:57 AM
CELAWSON53
MEMBER
Somewhat. How do you remove the mount on neutral safety switch?
Nov 2, 2019 at 10:06 AM
Just remove the 2 attaching bolts. I attached a picture of the screw locations.
Nov 2, 2019 at 10:15 AM
CELAWSON53
MEMBER
The shifter linkage mount binds the back bolt?
Jul 15, 2022 at 4:39 AM
You must remove the shifter linkage first.
Jul 15, 2022 at 4:40 AM
Add image or video
Ask a new question
Engine won't start
Engine overheating
