Neutral safety switch location
175,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
CHRISTOPHER L
The shifter is very hard to put into gear. could this be a neutral safety switch? if so where is it located and how do we get to it?
Mar 20, 2019 at 12:54 PM
  • 110,248 POSTS
Welcome to 2CarPros.
The neutral safety switch on this vehicle is part of the range sensor switch. That isn't the problem. There was a technical service bulletin related to this issue. Here it is:
_________________________
A/T - HIGH EFFORT TO OPERATE CONTROL (GEAR SHIFT) LEVER
File In Section: 07 - Transmission/Transaxle
Bulletin No.: 00-07-30-008
Date: May, 2000
TECHNICAL
Subject:
High Effort to Operate Automatic Transmission Control (Gear Shift) Lever (Replace Automatic Transmission Range Selector Lever Cable Assembly and/or Automatic Transmission Control (Gear Shift) Lever Assembly)
Models:
2000 Buick LeSabre
Condition
Some customers may comment that it requires a high effort to move the Automatic Transmission Control (Gear Shift) Lever to a desired position. The high effort is required in either direction and frequently causes "overshooting" the desired position.
Correction
FOR VEHICLES BUILT AFTER THE FOLLOWING VIN BREAKPOINTS:
Plant VIN Breakpoint Orion Y4128912 Hamtramck YU143005
In August, 1999, an improved Automatic Transmission Range Selector Lever Cable Assembly was implemented into production in order to reduce the gear shift lever effort. However, as part of a continuing effort to ensure a high level of customer satisfaction a new Automatic Transmission Control (Gear Shift) Lever Assembly is now available from GMSPO. Replace the existing Automatic Transmission Control (Gear Shift) Lever Assembly with the new assembly, P/N 26056013 (without Traction Control) or P/N 26056014 (with Traction Control).
Important:
DO NOT reuse the Torx(R) head fastener. Install the shift lever with a new Automatic Transmission Control Lever Bolt/Screw, P/N 14094899. Install the control lever bolt/screw.
Tighten
Tighten the bolt/screw to 19 Nm (14 lb ft). Refer to the Steering Wheel and Column-Tilt sub-section of the Service Manual for replacement procedures.
FOR VEHICLES BUILT PRIOR TO THE FOLLOWING VIN BREAKPOINTS:
Plant VIN Breakpoint Orion Y4128913 Hamtramck YU143006
1. Confirm the condition and note the required effort.
2. Replace the existing Automatic Transmission Range Selector Lever Cable Assembly with the new assembly, P/N 25713786. Refer to the Automatic Transaxle-4T65-E sub-section of the Service Manual for replacement and adjustment procedures.
3. Move the Automatic Transmission Control (Gear Shift) Lever and note the required effort. Record the information and compare it to Step 1.
4. If the gear shift lever effort has not been sufficiently reduced to ensure customer satisfaction, replace the existing Automatic Transmission Control (Gear Shift) Lever Assembly with the new assembly, P/N 26056013 (without Traction Control) or P/N 26056014 (with Traction Control).
Important:
Tighten
Parts Information
Part Number Description 26056013 Automatic Transmission Control (Gear Shift) Lever Asm (without NW9 - Traction Control) 26056014 Automatic Transmission Control (Gear Shift) Lever Asm (with NW9 - Traction Control) 25713786 Automatic Transmission Range Selector Lever Cable Asm 14094899 Automatic Transmission Control Lever Bolt/Screw
Parts are currently available from GMSPO.
Warranty Information
See Picture 1
______________________________________
Let me know if this helps.
Mar 20, 2019 at 1:35 PM
CHRISTOPHER L
I've disconnected the gear shift cable and tried to move the gear select at the transmission it very hard to move. by doing this I've eliminated the cable and shifter it's internal of the transmission. is there something in there something in that I can do and is that wear the neutral safety switch is?
Mar 21, 2019 at 2:37 AM
  • 110,248 POSTS
Welcome back:
If it is still tight, then you need to take it apart to determine the cause. Yes, the neutral switch is part of the range sensor on this vehicle.
Mar 22, 2019 at 1:54 PM
