Neutral safety switch?
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the transmission identified and checked for faults, fluid condition and level using its specified procedure. If pressure testing is indicated, it requires transmission-rated equipment, the correct ports and the manufacturer's limits. Avoid further load testing until assessed.
Guidance references and applicability
2CarPros: Original discussion 1711587 https://2carpros.com/questions/neutral-safety-switch-56582350 Source for reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. Attachments were not verified.
William
It looks like you will need to purchase or rent an oil pressure gauge kit so get a reading for the transmission pump pressure. That will be the first step in diagnosing transmission issues. Of course make sure the fluid level is correct and in proper condition. If you can, you should also scan the system for codes for any clues that may relate to transmission engagement.
Hope this helps,
William
Discussion summary
The owner asked whether a neutral-safety switch could affect shifting, then described normal reverse operation but very limited forward movement while engine speed increased. The owner said the driven wheels spun when raised.
Reported outcome: No pressure measurements, confirmed switch fault or successful repair were reported.
Wheel movement while raised did not establish that the transmission could transmit normal driving load. The thread does not prove a range-sensor fault or provide a complete pressure-test procedure.
