Neutral safety switch?
130,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
KARMALOVE1415
Does the neutral safety switch have anything to do with the transmission shifting in and out of gear
Dec 11, 2025 at 1:57 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the transmission identified and checked for faults, fluid condition and level using its specified procedure. If pressure testing is indicated, it requires transmission-rated equipment, the correct ports and the manufacturer's limits. Avoid further load testing until assessed.
Guidance references and applicability
2CarPros: Original discussion 1711587 https://2carpros.com/questions/neutral-safety-switch-56582350 Source for reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. Attachments were not verified.
Read the replies · Discussion summary and reported outcome
CANNON1349
  • 861 POSTS
Hello, if the range sensor is out of adjustment it can interfere with shifting considering it moves the manual valve in the transmission. What kind of issues are you experiencing with the shifting?
William
Dec 11, 2025 at 9:18 AM
KARMALOVE1415
The car moves fine in reverse but when I put it in drive it will start to go but won't move no faster than 5 mph but the engine will continue to rev like it's accelerating but if I lift the rear tires in the air the tires spin at the speed it's supposed to
Mar 3, 2026 at 3:59 PM
CANNON1349
  • 861 POSTS
It looks like you will need to purchase or rent an oil pressure gauge kit so get a reading for the transmission pump pressure. That will be the first step in diagnosing transmission issues. Of course make sure the fluid level is correct and in proper condition. If you can, you should also scan the system for codes for any clues that may relate to transmission engagement.
Hope this helps,
William
Mar 4, 2026 at 10:03 AM
Discussion summary
The owner asked whether a neutral-safety switch could affect shifting, then described normal reverse operation but very limited forward movement while engine speed increased. The owner said the driven wheels spun when raised.
Reported outcome: No pressure measurements, confirmed switch fault or successful repair were reported.
Wheel movement while raised did not establish that the transmission could transmit normal driving load. The thread does not prove a range-sensor fault or provide a complete pressure-test procedure.
Read the original discussion
