No crank no start, possible Neutral Safety Switch issue?
183,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
TRAVISK
  • 8 POSTS
well it won't start or crank all of dash is working I think it's my neutral safety switch but I don't know what wires to bypass it. Can anyone help?
Feb 6, 2025 at 1:16 AM
CARDOCTOR74
  • 62 POSTS
Hi Rob here. The absolute very first thing I would check is to make sure the battery has 12 V on an extreme load. Check it with your meter while someone tries to crank it over with the headlights on and blower motor, etc. I would then make sure the battery and terminals and grounds are secure and there’s no damage there as well as that can affect the starting circuit. Also make sure if you have power and ground going to the starter. If you do have power and ground that starter is seized and will need to be replaced. Another thing you can try is to see if it does start a neutral then yes, the neutral safety, which can be the issue. If it does not, you need to check the other items I stated and lastly, the engine could’ve seized. You can try turning the crankshaft with a socket and ratchet by hand to rule that out. These would be the first steps I would take to get this thing started.
Feb 6, 2025 at 5:01 AM
TRAVISK
  • 8 POSTS
Well, I tried everything you suggest, and it's not seized up and plenty of battery, no gears showing up still no crank or starting. anymore suggestions?
Feb 6, 2025 at 8:17 AM
CARDOCTOR74
  • 62 POSTS
May be the switch. Does this have the floor or column shifter ?
Feb 6, 2025 at 8:32 AM
TRAVISK
  • 8 POSTS
Floor
Feb 6, 2025 at 8:38 AM
CARDOCTOR74
  • 62 POSTS
Transmission range sensor is built into the floor shifter assembly, it is not serviced separately, the floor shifter has to be replaced if the sensor is bad. I attached the link.
If you feel this helped, I’m not against a tip thanks again.
https://venmo.com/u/hondaguygold
Feb 6, 2025 at 8:43 AM
CARDOCTOR74
  • 62 POSTS
2
Feb 6, 2025 at 8:44 AM
TRAVISK
  • 8 POSTS
Thanks. I'll try that today and let you know if it works.
Feb 6, 2025 at 5:48 PM
CARDOCTOR74
  • 62 POSTS
Again glad to help. I’m here if you need me.
Feb 6, 2025 at 9:55 PM
TRAVISK
  • 8 POSTS
Hey Rob it's me again. I put the floor shifter in and the something, no gears on the dash and no start so I hotwired the starter and it's good what else could it be?
Feb 10, 2025 at 1:21 AM
CARDOCTOR74
  • 62 POSTS
Still no lights on the dash if fuses are good and no wire damage as well it may be a PCM issue. At this point I would scan for codes as well. But recheck all fuses and wiring.
Feb 10, 2025 at 1:41 AM
TRAVISK
  • 8 POSTS
Oh yeah, I forgot to mention when I plug my code reader in all it says is (ERROR).
Feb 10, 2025 at 2:08 AM
TRAVISK
  • 8 POSTS
I tried another one, but it says no communications with the system.
Feb 10, 2025 at 2:09 AM
CARDOCTOR74
  • 62 POSTS
No communication that’s telling you that PCM is shorted out internally if there’s no wire or fuse damage.
Feb 10, 2025 at 4:18 AM
TRAVISK
  • 8 POSTS
So I got one from another car will that work.
Feb 10, 2025 at 4:50 AM
CARDOCTOR74
  • 62 POSTS
It will need to be programmed to the vehicle, unfortunately.
Feb 10, 2025 at 8:30 AM
