Neutral safety switch location
139,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALLEN IVANOFF
Where is it located and difficulty changing it from one to ten?
Jan 13, 2018 at 4:32 AM
CARADIODOC
  • 34,415 POSTS
It is on the shift lever on the transmission. Must be in "neutral" when installing a new switch that is pinned in neutral. If the pin is broken, or an old switch is being reinstalled, there is a procedure that involves dropping a pin in the hole to hold it in adjustment while the mounting bolts are being tightened.
Jan 13, 2018 at 5:52 AM
