Message, traction disabled, oil change, brake fluid and check engine light
15,000 MILES • V8 • 4WD
KEMOLADY92
I just recently bought this car from a man and it is reading traction disabled, oil change, brake fluid and check.engine light. This is my first car purchase I want to know best option for me and this car and about how much it will cost?
Mar 25, 2019 at 5:31 AM
JOETECHPRO
  • 705 POSTS
Hey KEMOLADY92,
Please read the guide below on how to check for fault codes.
If you can check for fault codes and report back with what you have we can give you further advise on where to start.
The codes could be cause as something as simple as a bad electrical connection.
Are you experiencing any running issues or drive-ability problems or just the warning lights?
Hope that helps.
Regards, Joe
Mar 25, 2019 at 10:40 AM
KEMOLADY92
I put everything that reads in dashboard i am not sure, I know nothing about cars. I really need help.
Mar 25, 2019 at 11:28 PM
JOETECHPRO
  • 705 POSTS
Hey KEMOLADY92,
As i said before you will need to read through the guide and follow it to get the fault codes.
If you do not feel confident with this then you can take it to a shop, or find someone with a reader who will help you. Just getting the codes read initially should be inexpensive.
I then may be able to run you through some checks you can do yourself or inform you on how much it may cost and what the process will be.
First step we have to have the fault codes.
Regards, Joe
Mar 26, 2019 at 1:24 AM
