Need upstream o2 sensor (bank2) wiring diagram?
110,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
HABEEBAHM
  • 20 POSTS
The connector for upstream o2 sensor (bank2) was cut off due to a recent accident. Can someone help me with the layout of the connector? something like attached pic will be helpful.
Apr 26, 2023 at 6:42 PM
BORIS K
  • 836 POSTS
Please see pin out in image below.
Pin 1, white wire
Pin 2, grey/violet wire
Pin 3, green wire
Pin 4, not used
Pin 5, white/green wire
Pin 6, violet/green wire
Pin 7, brown/blue wire
Cheers, Boris
Apr 27, 2023 at 1:14 AM
HABEEBAHM
  • 20 POSTS
thank you for the help. it worked !!
Apr 28, 2023 at 8:17 PM
  • 55,694 POSTS
BORIS K is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
May 1, 2023 at 2:51 AM
