NEED TORQUE SPECS FOR THE MOTOR ASSEMBLY
21,000 MILES • 4 CYL • 2WD • AUTOMATIC
FELIX86RAMIREZ
REPLACING HEAD GASKET NEED 2012 TOYOTA CAMRY LE MOTOR ASSEMBLY SPECS
Oct 16, 2014 at 12:00 PM
  • 110,248 POSTS
Can you narrow this down a bit. It will take a week to find every spec for the engine. Are you looking for head bolt torque?
Oct 16, 2014 at 12:20 PM
FELIX86RAMIREZ
Yes, sorry. Its the head bolts spec that i am needing. I need to replace the head gasket on the vehicle and need to know those torque specs.
Oct 16, 2014 at 12:33 PM
  • 110,248 POSTS
This is a 4 step process.
1 - tighten bolts to 27 ft/lbs\
2 - re-tighten the bolts to the same 27 ft/lbs
3 - turn each head bolt an additional 90 degrees
4 - turn each bolt an additional 90 degrees.
You will need a 10mm bi-hexagon wrench. Additionally, there is a specific sequence in which the bolts needs tightened. However, it isn't showing up in my online manual.
Oct 16, 2014 at 12:47 PM
FELIX86RAMIREZ
Thanks! Do you happen to have a link to that online manual? Or can you post a picture of the diagram, if there is one.
Oct 16, 2014 at 12:52 PM
  • 110,248 POSTS
Hi:
The program I uses is Mitchel Online. The address is Prodemand.com. The problem is that there is no actual pic for the sequence. It has a place for the pic and it is titled sequence, but no picture is available.
Oct 17, 2014 at 10:16 AM
