Need torque specs for rear trailing arm bolts?
45,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
DW1
The trailing arms on this car are quite rusty and are being replaced. To properly install the new parts I need the torque specs for the trailing arm to knuckle bolts and the trailing arm to body bolts. Thank you.
Sep 15, 2022 at 10:28 AM
  • 110,251 POSTS
If you look below, I attached the torque specifications for the rear suspension. The list includes the trailing arms.
Taake a look through it and let me know if it helps.
See pic below.
Sep 15, 2022 at 2:07 PM
DW1
Thank you for this information. I see the trailing arm to knuckle spec, but not the torque spec for the bolts that attach the trailing to the underbody. These are #38 on the FLO (fastener location overview) diagram referenced in the list you posted. Might they be the same torque as the #41 trailing arm to knuckle bolts?
Also, are there any special precautions for stabilizing/immobilizing the rear suspension when the trailing arms are removed?
Sep 17, 2022 at 10:34 AM
  • 110,251 POSTS
For some reason, they don't have that listed. What size is the bolt? Does it look like it can handle 150 ft/lbs? Considering what it's holding, I would think it would be the same torque.
Sep 17, 2022 at 3:07 PM
