Torque settings on cylinder head and big end bearings needed
170,000 MILES • 1.0L • 4 CYL • 4WD • MANUAL
HENRICO ELVIN
Need torque settings on cylinder head and big end bearings.
Jun 21, 2018 at 5:01 PM
  • 55,658 POSTS
Here are the engine torque spec you have requested:
Camshaft Cap Bolts 16 Nm (12 ft. lbs.)
Cylinder Head Bolts - Camshaft Support Housing and Cylinder Head Mounting Bolts 25 Nm+60°+60°+60°+15°(18 ft. lbs.+60°+60°+60°+10°)
Crankshaft Bearing Cap Bolts 50 Nm+45°+15°(37 ft. lbs.+45°+15°)
Connecting Rod Bearing Cap Bolts 25 Nm+30°+15°(18 ft. lbs.+30°+15°)
Cheers, Ken
Jun 23, 2018 at 6:19 AM
