My serpentine belt broke two days ago. I need to know how go about replacing it.
Aug 15, 2016 at 10:00 AM
HMAC300
✓Experienced Mechanic
it is pretty easy, replace the tensioner as well and make sure the belt lines up with everything. also check for junk in pulleys like brush them off see picture. you will need the screwdriver to pry tensioner away from belt and should have tension taken with a gauge though.
