need to replace fuel pump which fuel pump strainer do i use, inlet size .3125 or.375 and where does it go?
85,000 MILES
COLTFAN
replacing fuel pump on 1984 dodge / plymouth turbo colt import and i need to know which fuel pump strainer to use one with inlet size of .3125 or one with inlet size .375 and where does the strainer go?
Jun 1, 2013 at 11:15 AM
  • 110,244 POSTS
I would recommend that you remove the strainer (which I believe is in the fuel tank) and take it with you to compare it to the ones available. Your car could have either one in it.
Jun 2, 2013 at 2:45 AM
