No start issue and while driving dash lights turned off
309,111 MILES • V6 • 4WD • AUTOMATIC
DENISHA.JORDAN
  • 7 POSTS
Start off with my dash lights going off while I was driving. I put the car in park and cut the car off try to crank it again and it wouldn’t start. I get a jump put the cables on the car and take them off the car cuts right back off. So I went and bought an alternator today and now I can’t get the key to turn in the ignition switch and the steering wheel is unlocked. I also bought a new key it still won’t turn. please help. I don’t know what’s wrong.
Dec 30, 2019 at 11:47 AM
Good morning,
Sounds like the battery is dead. Without voltage, nothing will work. You will need to replace the battery. The alternator may have been the issue that failed the battery but the battery needs to provide power to the car.
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Dec 30, 2019 at 11:54 PM
DENISHA.JORDAN
  • 7 POSTS
I got a jump the switch wasn’t off. I guess so when I turn switch off so battery could charge. the key won’t turn in ignition still. but I’ll check battery again.
Dec 31, 2019 at 12:27 AM
Do not jump a dead battery. You could damage modules. Either charge it with a charger or replace it.
Dec 31, 2019 at 12:45 AM
DENISHA.JORDAN
  • 7 POSTS
Okay I’ll charge it. so would that be the reason the key won’t turn in ignition cause steering wheel is unlocked just key won’t do anything ?
Dec 31, 2019 at 12:49 AM
That is correct. Low voltage will cause this.
Dec 31, 2019 at 12:55 AM
DENISHA.JORDAN
  • 7 POSTS
Okay, I’m going to give it a try. thank you! Be in touch.
Dec 31, 2019 at 1:05 AM
You are welcome.
always glad to help.
Dec 31, 2019 at 1:14 AM
DENISHA.JORDAN
  • 7 POSTS
Battery charged key still won’t turn... as moves the battery I heard clicks on and off, but then the lights would cut off in car. I do not know if it’s a shortage somewhere or what.
Dec 31, 2019 at 11:39 PM
What is the voltage at the battery?
Jan 1, 2020 at 12:08 AM
DENISHA.JORDAN
  • 7 POSTS
I do not know. I got it charged at the AutoZone overnight he said the battery was good. but as the guy was moving the battery around or touching. it is was like it was a shortage or some light would come on and off when I put the battery in. the alarm was sound so I cut it off but switch is still locked.. I was also told if I get a new switch put in it would have to be programmed! Guess I’ll just put it in shop because I really don’t know what’s wrong... but one time my service light came on n said I needed camshaft or some was going bad. but it had went off after it got diagnose maybe that’s it. I do not know.
Jan 1, 2020 at 12:19 AM
Make sure the cables that attach to the battery are clean and tight.
Jan 1, 2020 at 12:21 AM
DENISHA.JORDAN
  • 7 POSTS
Ugh, okay.
Jan 1, 2020 at 12:58 AM
Keep me updated.
Jan 1, 2020 at 1:04 AM
