Need to know how to change a gas pedal
250,000 MILES
LCS565
My son just bought this car and it has no gas pedal. It has the metal stick thing coming down from the firewall but nothing attached to the end. We found a car to get parts from at picknpull but not sure if tools are needed to get the part off the car or how to do it.
Jul 21, 2013 at 5:41 AM
CARADIODOC
  • 34,413 POSTS
You wouldn't go to the yard with no tool box or just one wrench. You have the perfect opportunity to answer your own question by looking at the donor car. Also look at yours to see if there's any indication the pedal was bolted to the floor. If it was, the lever hanging down won't have any holes or attaching points on it. Many pedals do not bolt to the floor. Instead, they pivot on the end of the lever. Most likely you'll need a pliers to pull a retaining pin to get that type off.
Jul 21, 2013 at 6:22 AM
