need to get power to 1/4 & 2/6 wires going to the coil pack
200 MILES • 3.3L • 6 CYL • FWD • AUTOMATIC
MAXWELLHART
I am getting power to my 3/5 cylinder wire coming off the wire harness but not from the wire for 1/4 & 2/6 coming off the wire harness what all do I need to check I already changed the pcm.?
May 29, 2014 at 2:17 AM
HMAC300
  • 48,601 POSTS
you need to scan for codes first to see what the cause is.
May 29, 2014 at 2:32 AM
MAXWELLHART
i scan the pcm and they are no codes.
May 29, 2014 at 3:15 AM
HMAC300
  • 48,601 POSTS
actually iforgot there won't be because you got rid of theone that had it stored. check your cam and crank sensors for resistance against new ones. check orange wire on crank sensor for 5-8 volts if voltage more than 7 volts replace cam sensor. ifnot that have a pro look at it. Also check your asd relay it may also be the cause switch with a like relay.
May 29, 2014 at 5:09 AM
