Where is the fuel pump relay located?
1991 DODGE CARAVAN
70,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
RONALD STORLIE
I need to change fuel filter.
Jan 27, 2022 at 3:30 AM
SQM
  • 6,383 POSTS
The fuel pump relay is located on the rear right hand side of the engine compartment, if you are facing the engine (see diagram below)
The in-line fuel filter is found along the right-side frame rail between the fuel tank and engine.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jan 27, 2022 at 4:31 AM
