Where is the ABS fuse located?
200,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
EJAMAL95
My car sometimes won’t drive at all and other just hear a noise took it to a shop they didn’t do ABS work but said that’s the problem and the brakes and engaging themselves.
Jun 14, 2023 at 5:28 AM
  • 110,248 POSTS
When you hear the noise, does the brake pedal seem much stiffer or do you feel any vibration through the pedal?
I ask because I'm not sure how the ABS would turn itself on. If it is actuating, something such as a wheel speed sensor is failing and causing it.
I attached the wiring schematic below for the ABS/Traction control so that you have a reference. I highlighted 4 fuses that are related to the ABS control module.
Let me know if that helps or if you have questions.
take care,
joe
See pics below. Note: I had to cut the schematic in two to make it readable for you. I did overlap the two so you can follow from one to the next.
Jun 14, 2023 at 4:26 PM
