Need to discharge rear air suspension
2005 LINCOLN NAVIGATOR
155,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
DON431
  • 5 POSTS
Converting air suspension to struts. Rear air socks are almost fully pumped up. Want to discharge before i remove them. Any idea how?
Nov 15, 2020 at 1:42 PM
If you have a scan tool you can deflate the system. I attached the process.
If not then look at number two you will see the air spring. It will have an air line going to it. I would just support frame of the vehicle with a jack and remove the air line. Clearly you will get a burst of air but if the vehicle is supported with a jack, it won't drop when you remove it. Just make sure you turn the air suspension switch off so that the compressor doesn't run to try and fill the system.
Let me know if you have questions. Thanks
Nov 15, 2020 at 1:56 PM
Good evening,
If I can throw in my 2 cents, removing the line can release a lot of pressure.
If you jack the car up in the front with the key off, the vent solenoids will open and exhaust the air.
Do the same to the rear and then they will all be free of air.
I always err on the side of caution.
Nov 15, 2020 at 2:09 PM
DON431
  • 5 POSTS
Thanks for your response Roy.
My rear bags don't seem to bleed down. The rear solenoids aren't opening. {The original condition was front bags wouldn't inflate and rear bags wouldn't deflate.}
Just changed the front to struts today. Want to do rears ASAP but for safety want to bleed rear bags before removing.
Nov 15, 2020 at 2:54 PM
DON431
  • 5 POSTS
Thanks KaseKenny1.
I can do that. I was just concerned the amount of air might be dangerous to remove line under pressure.
Nov 15, 2020 at 2:59 PM
Okay, disconnect the height rod at the rear and move it up and down and see if it opens the solenoids.
Be careful if you are under it.
I attached a picture of it for you.
Nov 15, 2020 at 3:00 PM
DON431
  • 5 POSTS
Okay, I will try it. Thank you.
Nov 15, 2020 at 3:04 PM
Understood. Just to be clear, if you have the vehicle supported then it is just releasing the air from the top of the spring. Clearly if the vehicle is sitting on the suspension and you do it, it will drop. However, I get how you may not want to do it this way.
If you release the rod as Roy stated, just try to support the vehicle as well. As he stated, you need to be careful if you are doing it on the ground and you are under it. No matter what you do, just make sure you have it supported so that you can control the drop of the vehicle while you are out from under it.
Let us know how you make out. Thanks
Nov 15, 2020 at 3:24 PM
DON431
  • 5 POSTS
So just to update:
Finally replaced Air Suspension bags with Monroe Strut Assembles. Very happy with ride..
Discharging bags required removing solenoids from bags which was easy and air pressure didn't present any danger.
Now I have to figure out how to remove "Check Air Suspension Light" on Dash..
Any Suggestions?.
Nov 25, 2020 at 4:15 AM
This will not be easy as the system is always set to default and the light will come on. Disconnecting fuses will not do it as other systems are tied into the fuses as well.
The only way to do it is to remove the cluster and remove the bulb. There will always be codes set for the suspension.
I attached the procedure and some pictures for you.
INSTRUMENT CLUSTER
Removal and Installation
All vehicles
CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
1. NOTE: Prior to removal of the instrument cluster, it is necessary to upload the instrument cluster configuration information to the diagnostic tool.
Depower the supplemental restraint system.
2. Remove the instrument panel finish panel.
Expedition
3. Remove the screws and pull the instrument cluster out from the instrument panel.
4. Remove the instrument cluster.
Press the retaining tabs, remove the transmission range selector, and position aside.
Disconnect the electrical connectors.
Navigator
5. Remove the 4 screws and pull the instrument cluster out from the instrument panel.
6. Disconnect the electrical connectors and remove the instrument cluster.
All vehicles
7. To install, reverse the removal procedure.
Download the instrument cluster configuration information from the diagnostic tool into the new instrument cluster.
Nov 25, 2020 at 4:27 AM
