Need to change clutch slave cylinder
100,000 MILES • 4 CYL • 2WD • MANUAL
SHEILA BAUMGARTNER
How to replace clutch slave cylinder?
Sep 24, 2019 at 1:07 AM
Good morning,
The slave cylinder is part of the throwout bearing and the transmission must be removed to access the slave cylinder.
Are you prepared to do this operation?
https://www.2carpros.com/articles/how-to-replace-a-clutch
If you are, I will get you all the steps but you will need a lift and some special tools.
https://www.youtube.com/watch?v=ZjQsM_R3ZUQ
Sep 24, 2019 at 1:24 AM
