Can I get the head bolt torque spec and sequence?
160,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
ROGELIOMCP1
Can you please tell me the head bolt torque spec and sequence for a 2011 Cadillac escalade?
Feb 23, 2023 at 4:12 AM
ROGELIOMCP1
It’s actually a 2017 not a 2011. sorry, I don’t know why it did that.
Feb 23, 2023 at 4:15 AM
  • 110,248 POSTS
No problem whatsoever. When you install the heads, note there are different directions for each side. The torque is the same.
Additionally, note torquing requires a few steps. You really should have an angle-degree torque wrench gauge. They are inexpensive. I attached a pic of one from Amazon. It's under ten dollars. Once you do a basic torque of 59 foot-pounds, the next passes are done by the degrees the bolt turns.
I placed an L and R on the pictures, so you know which is the left and right head.
Feb 23, 2023 at 12:14 PM
