Need the procedute to retime a Mitsubishi 2.5
66,000 MILES • 2.5L • 6 CYL • 2WD • AUTOMATIC
JLARSON69
  • 10 POSTS
I was changing the timing belt on a 1998 Dodge Avenger with the Mitsubishi motor. I used the puller on the crankshaft pulley and I forgot to put the bolt back in so I took off the timing belt pulley also. Now my marks are no longer in alignment. How do I reset the timing on this car?
Aug 19, 2014 at 11:40 AM
  • 110,248 POSTS
Here are the timing mark diagrams. Let me know if they help.
Aug 19, 2014 at 11:51 AM
  • 110,248 POSTS
Sorry, I forgot to attach the link,
https://www.2carpros.com/diagrams/dodge/avenger/1998
JLARSON69
  • 10 POSTS
So I can just move the camshafts and the crankshaft manually to the mark?
Aug 19, 2014 at 11:55 AM
  • 110,248 POSTS
Yes, they must be pointing in the correct direction. My concern is that this is an interference engine. You must make sure the marks are correct or it could cause internal engine damage.
Aug 19, 2014 at 12:11 PM
JLARSON69
  • 10 POSTS
Is it possible to get the cam or crank marks 180 degrees off?
Aug 19, 2014 at 1:14 PM
  • 110,248 POSTS
Not as long as they are pointing at the timing marks provided.
Aug 20, 2014 at 10:27 AM
JLARSON69
  • 10 POSTS
Thank you for all the help. I got it retimed and it runs great. Now I have a major oil leak from the rear valve cover. I used new Fel-Pro gaskets and torqued the bolts to 31 in lbs. Any suggestions?
Aug 25, 2014 at 8:32 AM
  • 110,248 POSTS
Did you use a rubber or cork gasket? Before you replaced the cover, did you check to make sure none of the bolt holes were stretched and in need of making flat again?
Aug 25, 2014 at 11:34 AM
