Mine snapped and i can't get the hood to open. Diagram or help is very much appreciated!! Will send pics if needed.
Apr 16, 2024 at 11:12 AM
✓Experienced Mechanic
We don't have this information sorry; did you check to see if the problem is at the handle? Also, try to pull the hood release while pulling up on the hood and move it side to side. I have seen where the grill must be removed to get at the hood release. There is no one way to deal with this problem, can you upload images so I can help ?
Apr 17, 2024 at 3:13 AM
SCION
MEMBER
I got it open. Thank you. To open it, on the driver's side, there is a gray bar behind the headlight. It's the first thing you see. On the top, where the bar takes a turn down, put a big flat screwdriver and wedge under it. Twist and boom.
Apr 17, 2024 at 12:25 PM
Glad you could get it fixed, thanks for letting us know. Please use 2CarPros anytime we are here to help.
