need shorter serpentine belt number for bypass
2002 CHRYSLER SEBRING
184,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RJSEE
A/C compressor run tight. shop quoted $1.500.00 repair. can this be bypassed without a bypass pulley by using a shorter belt? Not putting $1.500.00 in this car. need a belt number or belt length if possible to bypass. Thanks
Jan 6, 2018 at 1:37 AM
WRENCHTECH
  • 20,761 POSTS
You can rule out a shorter belt because the routing would cause the belt to contact things. They do may eliminator pulleys for some cars but not all so you will have to contact the parts store to check on availability for your car. I am guessing putting a compressor on it may be your only option.
Jan 6, 2018 at 8:35 AM
