Need Serpentine Belt Diagram?
80,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JSALO23
Please provide Serpentine Belt Diagram for the vehicle listed above. Thank you
Sep 21, 2023 at 2:53 AM
  • 110,248 POSTS
As far as the belt diagram is concerned, I attached it below for you. When you replace this, I believe there is a mechanical adjuster and not an automatic one.
If you look at the pic I attached, it shows the manual adjuster on the side of the alternator. When you want to loosen or tighten the belt, make sure the bolts I circled in pic 2 are loosened before turning the adjuster bolt.
Sep 21, 2023 at 2:01 PM
