Need name of part
100,600 MILES • V6 • 2WD • AUTOMATIC
PAIGE OWENS
I am unsure of the name of the part that is circled. The wire/tube is broken and has a tear. I need to replace it, but I am not sure what it is. It looks like a spark plug wire but it is not. I have circled it in the image below.
Feb 15, 2017 at 11:13 AM
PAIGE OWENS
Could this being broken keep the car from starting? The battery is good (new), has gas, no codes, air filter is decent. The car will not crank/turn over. I know I need to check the starter circuit system but have not yet. Any other suggestions?
Feb 16, 2017 at 10:36 AM
CJ MEDEVAC
  • 11,000 POSTS
Looks like the PCV hose/ elbow
It snaps onto the PCV (positive crankcase ventilation)
The PCV itself is held in place by that rubber grommet in the valve cover.
Probably can be found in a local parts store (maybe in the "Help" section)
The Medic
