Replaced all coil packs, new sparks plugs (Motorcraft). replaced motor 2k miles ago (crate motor) etc.
Aug 30, 2022 at 6:28 AM
✓Experienced Mechanic
Nice work, so we had a problem with a truck like this and it turned out the spark plugs were counterfeit ones from China. I would recheck the spark plugs for cracks and to make sure they are genuine motor craft plugs, if you got them from Amazon, they are probably fake. Here is a video:
I've seen that video before, lol. thanks. You are right. I bought eBay Motorcraft spark plugs, but I found a loose pigtail connection on a coil pack on piston 3 bank 1.
Aug 31, 2022 at 5:08 AM
JOHN1024
MEMBER
I replaced pig tail. Engine slightly vibrates. I will be changing sparkplug to original. Can you please help me get a fuel pump sending unit diagram? There's 4 plug pin. I have 2 grounds and 2 powers. One gets 12v and the other one gets 7v.
Video (Click to enlarge)
Aug 31, 2022 at 5:11 AM
Okay, here are the fuel pump wiring diagrams but they are included in the engine wiring, so I have to get you the complete set. You can save this post in your favorites, so you have them for reference later on if needed.
Images (Click to enlarge)
Sep 2, 2022 at 1:57 AM
JOHN1024
MEMBER
Thank you very much for your help. My truck is running better. It has a check engine light on. drives great at low RPMs, when I gas it on first or second gear it chugs. I will pull out codes once the system cycles. thanks again
Sep 2, 2022 at 3:01 AM
Use 2CarPros anytime, we are here to help. Please tell a friend.
