Need help with PCM
237,452 MILES • 4.0L • V6 • 4WD • AUTOMATIC
TMCINTOSH11
  • 176 POSTS
So I finally found out that my PCM is not grounding one of my fuel injectors and needs replaced, which is not a huge problem except for one thing, the OEM number. Taking the entire PCM out intimidates me because one mechanic told me that once it is completely unplugged it has to be re-flashed. which stinks because if I could get the OEM number it would only cost me $200.00 for the part, and $60.00 to flash it, and $150.00 for installing. otherwise it is $1,175.00 for the part plus flash and install. So what would be a simple cheaper way to go about this? If I have to pay the $1,175.00 then I will but I really do not want to. any ideas? Thanks!
Oct 30, 2017 at 10:10 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I have 1L2Z12A650SD for manual transmission and if automatic transmission 1U7Z12A650GSB.
Oct 30, 2017 at 10:47 PM
TMCINTOSH11
  • 176 POSTS
Wow is that it? I thought it had to be a certain number only on the PCM itself, but if that is the OEM number I need then you just saved me! Thank you!
Oct 30, 2017 at 10:53 PM
STEVE W.
  • 15,409 POSTS
Those are the latest revised part numbers for that vehicle. As they update the hardware and software they alter the numbers so that you can tell what the unit is without needing to scan it to determine if it is the latest version. IE: the new version may have better transistors in the injector driver, or maybe they discovered that a different chip worked better.
Every change like that gets a different number. That is one of the ways they track problems in parts.
Oct 31, 2017 at 2:33 AM
TMCINTOSH11
  • 176 POSTS
Gotcha, I tried one parts store and they didn't list the 1U model but they listed the 1L model, I'll try napa in the morning, if all else fails what should I do then? Thanks guys!
Oct 31, 2017 at 10:49 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
TMCINTOSH11
  • 176 POSTS
I tried the link you gave me and it did not work, maybe because it does not work for a mobile,. But, I did try entering the U1 part number on Napa.com and it brought up two results. its part number is different than the one I entered but the pictures for both matched the PCM that is on my truck. should I trust it? Have I found my part? They are both also listed as re-manufactured, what do you think? Thanks!
Nov 1, 2017 at 11:47 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Remanufactured may be all that you can find. except used. I doubt if anyone is making new ones anymore for a 2002.
Ask Napa why their numbers are different, what is the difference and if it will fit, etc. I am sure they will know better than I would about the products this list or perhaps the manufacturer or whomever rebuilt it if the website or napa tells you.
To check a new one, try www.fordparts.com, although I will try there, too.
Once there click on model, then select the year, make, model and then click search catalog.
Nov 1, 2017 at 10:23 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Yes, they do have some, 160 to be exact. http://www.fordparts.com/Commerce/CatalogResults.aspx?y=2002&m=Ford&mo=Explorer&initSearch=1&keyword=control%20module#Search
I know you said links do not work for you, but try anyhow.
Try to narrow that down by entering your vin at the top of this page I just gave you.
If not, give me the VIN number.
Nov 1, 2017 at 10:26 PM
TMCINTOSH11
  • 176 POSTS
I tried the link and entered the VIN and it's listening it as the same price as the dealership but I called napa with the 1U number and they said it will work so I have my part, thank you guys so much for helping me find the part number I needed!
Nov 3, 2017 at 1:34 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome.
Nov 3, 2017 at 1:44 AM
STEVE W.
  • 15,409 POSTS
Nice job PATENTED_REPAIR_PRO
Nov 3, 2017 at 8:24 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Thanks Steve!
Nov 3, 2017 at 8:40 AM
