broken heat riser
1984 DODGE TRUCK
120 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JOHNNIE.SURICO
Slant six 225 motor exhaust manifold coil broke off heat riser. where can I get another coil and how does the front of pulley come off ?
Apr 29, 2021 at 12:19 PM
Good morning,
They do not offer the spring anywhere. The only repair is to replace the manifold.
I attached the procedure below for you for the repair as well as the part.
Apr 29, 2021 at 8:34 PM
