is still cranking but cannot seem to catch?
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
DANIEL NELSON2
  • 44 POSTS
need help with diagnosis. okay, so now i changed all the spark plugs and she is still cranking but can't seem to catch. i have checked the harnesses and everything could it possibly be the fuel pump relay.
Mar 13, 2025 at 8:43 AM
  • 55,746 POSTS
Yes it could be the fuel pump relay, but there are many other items that can cause a "no start" issue as well. I would go over this video to see what I am talking about; it goes over the easy stuff so we can get a battery idea which system has failed.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
If it runs on starting fluid, then we know it is the fuel system. Let us know how it goes.
Mar 14, 2025 at 3:15 AM
DANIEL NELSON2
  • 44 POSTS
Okay, well after checking everything it did not start with the starting fluid, but I also didn't hear anything from the fuel pump inside the gas tank, and the spark test was good too, it did spark. so, now I am still a little confused cause now it seems like it is the relay but since the starting fluid didn't work, I don't know.
Mar 14, 2025 at 8:44 AM
  • 55,746 POSTS
Thanks for going over the video. we need to check the engine compression or upload a short video of the engine cranking and I can tell if the engine is good or not. here is a guide to help you, pick up a compression gauge at the auto parts store, you can rent it for free.
Please go over this guide and get back to us.
Mar 15, 2025 at 3:30 AM
DANIEL NELSON2
  • 44 POSTS
Here is the video requested.
Mar 18, 2025 at 1:42 AM
  • 55,746 POSTS
It is hard to tell from the video, can you film the engine from under the hood? From what I can tell from this video it is not good, but I want to be sure.
Mar 18, 2025 at 2:46 AM
DANIEL NELSON2
  • 44 POSTS
Yeah sure thing sorry about that.
Mar 18, 2025 at 6:33 AM
DANIEL NELSON2
  • 44 POSTS
So anything?
Mar 19, 2025 at 12:48 AM
  • 55,746 POSTS
Wow, that engine is hurt, sorry. The engine will need to come apart to see what happened. You can confirm it with a compression test. Thanks for the video, it makes things easier for us.
Mar 19, 2025 at 3:33 AM
