Need help to setup wiring harness for a swap
4.0L • V6 • 4WD • MANUAL
TOMMY_BOY
  • 11 POSTS
The 2001 Ford Explorer wiring harness doesn't have that wire and the C110 plug for the motor wiring harness.
Don’t have that wire. So does have this instead.
__________________________________________________
40 -------------- 911 (WH/LG)
41 ----- 904 (LG/RD)
----- OR ----
1017 (BK/WH)
------- "Generator/Battery indicator, control"
42 ------ 36 (YE/WH) ------
"1 Voltage supplied at all times (overload protected)"
And I have C102a or b plug to the Generator
1 ------- 36 (YE/WH) ------
2 ----------- Not Used
3 ---- 904 (LG/RD) --------
I hope you all can understands what i am trying to tell you. So there is my problem am having what should I do for the ‘1017 (BK/WH) wire’ for the ‘Check cap indicator lamp’? Like I said the 2001 Ford Explorer wiring harness doesn’t have check cap indicator lamp wire in it at all…
Nov 20, 2020 at 11:12 PM
Sorry but it is not clear what your issue is. You have a check gas cap light on and you are trying to use a wiring harness that does not have that circuit in it?
If you can clarify this for us, I am sure we will be able to figure something out. However, just because a circuit is not in a connector doesn't mean you can't make it. Basically you just need to run a new wire from end to end and then secure it to the harness.
Thanks
Nov 22, 2020 at 4:47 AM
