First of all I already flush the radiator standard procedure, then I check around no leaks. I was waiting for the average flow of the coolant to see it go? But it didn't? Does that mean My radiator is in a blockage with debris? How else do I get it to circulate properly?
2nd question is how do (diy) I check or clean my heater core to clean/flush it, to check for any blockage?, could I also do a alternative to bypass this or not?
Thank you gladly appreciate the prosperity & cooperation.
May 21, 2014 at 10:08 PM
