Surges or hesitates before accelerating?
162,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
PENNY C MATURA
  • 5 POSTS
Recently my truck started running ragged, so I changed plus, wires, distributor, fuel filter, air filter, and gave it a gas treatment thinking maybe I had gotten bad gas. Does not do the surging or hesitation all the time before finally picking up speed. Thinking it may be TPS? Any advice would be greatly appreciated, you guys have always come through before. already priced the TPS and new fuel pump but want to get input before shelling out money for no reason. Thanks!
Jan 15, 2021 at 5:15 AM
  • 110,248 POSTS
Have you done a few preliminary checks? For example, have you checked for engine vacuum leaks or have you checked fuel pressure?
Let me know. Also, are there any odd sounds from the exhaust which could indicate a plugged converter and have you pulled diagnostic trouble codes?
https://youtu.be/b2IJGfImVvw
If you haven't checked for codes, do that. Most parts stores will do it free of charge.
Jan 16, 2021 at 8:09 AM
PENNY C MATURA
  • 5 POSTS
Hi Joe, thanks for reply and yes he is taking it to get diag. codes today and will do the fuel pressure test and check vacuum as well and I'll update you once that is done. It's an older Chevrolet truck getting up there in miles..
Jan 17, 2021 at 9:58 PM
  • 110,248 POSTS
They are great vehicles, but everything gets old. LOL Let me know.
Jan 18, 2021 at 5:13 AM
