lower control arm bushings
70,000 MILES
DAVID WARE
Does anybody know what bushings to use for the lower control arms? They do not make them anymore. Help please.
Jul 13, 2017 at 6:32 AM
STEVE W.
  • 15,406 POSTS
Well if the numbers are correct it should take ACDELCO 45G9092 for the front A arm rear bushings and ACDELCO 45G9090 for the front A arm front bushings.
Here are the listed dimensions.
45G9092 -
Length 2.76 IN
Inside Diameter 0.570 IN
Outside Diameter 1.670 in
45G9090 -
Length 2.60 IN
Inside Diameter 0.660 in
Outside Diameter 1.900 in
Jul 13, 2017 at 10:16 AM
DAVID WARE
Man I hope so I'd hate to junk the. Car only has 70.000 mil on it they are for the front lwr ??????
Jul 14, 2017 at 7:54 AM
DAVID WARE
Also thank u very much ....I tried every suspension shop in town and nobody could help
Jul 14, 2017 at 7:56 AM
STEVE W.
  • 15,406 POSTS
GM used the same parts on many cars BUT they changed part numbers a lot. What I did was use a couple after market part numbers that fir the car, then crossed those to newer numbers. If you measure up the old ones it should tell you if they fit.
Those are the numbers for the lower front A arm. There are 2 different bushings, one goes in the front of the arm the other in the back.
Jul 14, 2017 at 2:23 PM
