Leaking yellow fluid
171,000 MILES • 0.6L • V8 • AUTOMATIC
DAVIDBATT
My car is leaking yellow fluid and when put coolant in it will leak the yellow fluid. And I put more coolant in the overflow tank and stop leaks also and idle the car for fifteen minutes. It was leaking more than usual but when I turn off the car it stop leaking.
Oct 4, 2018 at 10:48 AM
  • 110,248 POSTS
It sounds like an engine coolant leak. Can you tell me aproximately where the leak is located?
The best thing to do is pressure test the system. Basically, you supply pressure to the cooling system which will cause the coolant to leak so you can locate the problem.
Here is a link that discusses how to check and repair a leak:
https://www.2carpros.com/articles/car-is-leaking-coolant
Take a look through that link and let me know if it helps.
If you have other questions, let me know.
Oct 4, 2018 at 11:06 AM
