Engine turns off when transmission is shifted into gear?
75,000 MILES • 2WD • AUTOMATIC
WANDA QUICK WARD
Car starts but when put in gear it cuts off.
Sep 27, 2021 at 12:53 AM
SQM
  • 6,383 POSTS
So the vehicle will start up just fine but when you put it in drive the engine shuts off?
When you start it up, does it idle rough?
Is your check engine light illuminated?
This issue could be triggered by a number of reasons. It could be sensor for the engine management system, it can also be a vacuum leak.
https://www.2carpros.com/articles/stall-at-idle
Please let me know little bit more information of what you are experiencing.
Sep 27, 2021 at 1:51 AM
