I am a mobile tech and computer crashed with my Aldata on it?
Sep 6, 2014 at 8:41 AM
WRENCHTECH
✓Experienced Mechanic
I assume this is a VIN 3 engine. I also assume you are referring to the cam bearing caps. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Sep 6, 2014 at 10:48 PM
BIGGY25
MEMBER
1 POST
1994 Ford Escort 4 cyl
what is the tightening sequence and torque for the head on a 1994 escort engine?
Jan 28, 2021 at 1:51 AM
(Merged)
Hey BIGGY25,
Here is the cylinder head bolt tightening sequence and the foot pound and newton meter specs.
Cylinder Head Bolt (1) 56-60 (76-81)
Please let us know if you need anything else.
Best, Ken
Image (Click to enlarge)
(Merged)
STEVEN82
MEMBER
what are the spec for the torque on cylinder head
Jan 28, 2021 at 1:52 AM
(Merged)
BLUELIGHTNIN6
1.9L engines..
Tighten the cylinder head bolts in sequence (refer to the illustration) to 44 ft. lbs. (60 Nm).
1.8L engines..
Tighten the bolts in the proper sequence (refer to the accompanying illustration) in two or three steps to 56-60 ft. lbs. (76-81 Nm).
Thanks for using 2CarPros.com!
(Merged)
STEVEN82
MEMBER
Engine Mechanical problem
1993 Ford Escort 4 cyl Front Wheel Drive Manual
