Navigation Screen does not light up at all, A/C and Heat not working?
296,986 MILES • 5.5L • 6 CYL • 4WD • AUTOMATIC
LEVI TILFORD
My Navigation Screen doesn't light up at all, my AC or Heat don't work at all. please help me figure this out. any ideas are very thankful I'm lost on this issue.
Feb 10, 2023 at 10:22 AM
  • 55,748 POSTS
It sounds like you're having some electrical issues with your 2004 Acura MDX. Here are a few steps you can try to troubleshoot the problem:
The first thing we need to do is check the fuse #9 and the accessory power relay here is a guide to help with the test please use it when the key is in the on position with the engine off. Also, I have included the fuse location in the images below.
Please let me know what you find. Please check the images below and get back to me.
Feb 11, 2023 at 1:23 AM
