Mystery stalling when put into drive?
187,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
HPANNELL94
I was on my way home from work several months ago now. My car stalled on me at a relight started back up just fine but when put into gear it shut off immediately as if I was turning my engine off. Please, please help I was told it was torque converter locked up. I did a swap with entirely different trans and still same thing happens seems as if it's only when the break is applied. Someone please help before I junk my car. Thanks
Oct 13, 2024 at 11:18 AM
  • 55,684 POSTS
Yep, let's run the codes to see if any are stored, here is a guide to help us get started on fixing the car:
If while you are going to a stop, can you put the car in neutral does the engine keep running or does it stall anyway?
Oct 14, 2024 at 3:28 AM
