my windows will not go down?
200,000 MILES • 4.6L • 6 CYL • 2WD • AUTOMATIC
BMAN1G
  • 48 POSTS
Does a fuse control them and power seats won't move.
Sep 9, 2023 at 4:55 AM
  • 110,248 POSTS
As far as the windows are concerned, power and ground are supplied by the body control module. There are two fuses, (19 and 20) in the under-hood fuse box that power the module.
I attached the wiring schematic below of the window circuit. First, confirm the two fuses are good. In addition to checking the fuses, confirm there is power to and from them.
If they are good, I need you to locate the BCM. There are three brown wires that provide ground. I need you to confirm there is continuity to ground at those wires. Pics 3 and 4 will help locate the BCM. Pic 5 shows the fuse to check.
Let me know what you find.
Sep 9, 2023 at 2:30 PM
BMAN1G
  • 48 POSTS
It works now was a wrong fuse in slot 19. Thank you so much 2CarPros is the best.
Sep 10, 2023 at 1:09 AM
  • 110,248 POSTS
You are very welcome. I'm glad I was able to help, and you got the problem resolved.
As always, it's a pleasure helping you so feel free to come back any time in the future. You are always welcome here.
joe
Sep 10, 2023 at 12:19 PM
