If I put on my wipers, I try to put it off when screen has been cleaned. But wipers will not stop until I switch off ignition. What's the fault?
Feb 26, 2020 at 8:08 AM
✓Experienced Mechanic
If you can not turn the wipers off, it sounds like either the switch or a relay issue. I apologize but this vehicle isn't offered in the US, so my technical information is very limited.
Check the wiper relay. Here is a link showing how to test a relay:
