Took off the fly wheel drive plate cover and is coming from there some where when I put water in the radiator it goes right through onto the ground
Dec 7, 2014 at 7:32 AM
WRENCHTECH
✓Experienced Mechanic
If it's truly coming from inside the bell housing, then it would likely be a bad freeze plug but make real sure it isn't leaking from the valley pan above and running inside the housing.
Dec 7, 2014 at 8:13 AM
KORIJAMES36
MEMBER
Where is the valley pan located
Dec 7, 2014 at 9:17 AM
KORIJAMES36
MEMBER
Does the transmission have to come out to replace the freeze plug
Dec 7, 2014 at 9:20 AM
WRENCHTECH
It would be under the intake if it has one but I can't tell you how it's set up because you never listed the engine that it has. Anything leaking near the back of the engine would run down in that direction.
