Transmission wiring harness
135,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
MICHELLESANDOVAL
How do I go from a 7 pin to a 5 pin connector?
Aug 15, 2019 at 8:02 PM
STEVE W.
  • 15,423 POSTS
What are you trying to do? Swap transmissions or something else? If it's a swap what year is the replacement. This is the 7 pin id.
7 Pin Main Case Connector
Pin 1--Temperature sensor High
Pin 2--Solenoid power
Pin 3--1-2/3-4 (Shift A) solenoid control
Pin 4--Temperature sensor Low
Pin 5--Not used
Pin 6--2-3 (Shift B) solenoid control
Pin 7--PWM Band solenoid control
Aug 15, 2019 at 8:13 PM
