My transmission slips?
190,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
RICH NEGRETE
I just replaced my water pump and thermostat and as soon as I got it back my transmission slips?
Jun 24, 2022 at 6:29 AM
  • 55,628 POSTS
When you replaced the water pump did you remove the radiator? If so, your transmission could be low on fluid but to be sure check out this instructional guide with the specific instructions below to help you on your car.
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
10. Fill the transmission to the proper level with DEXRON(R)III transmission fluid.
11. Check the Cold fluid level reading for initial fill only.
12. Inspect the oil pan gasket for leaks.
Jun 28, 2022 at 3:15 AM
