Traction control light stays on
42,000 MILES
CAVALIERDRIVER141
My traction control light stays on.
Apr 9, 2020 at 11:01 AM
This could be a number of things but the only way to know for sure is to get the codes that are part of that system. If you can't pull codes then just stop by a parts store as most of them pull them free of charge. Once we know the code we will have a better idea as to what the issue is and can start testing.
Here is a good video on this system if you are interested:
https://youtu.be/K5AJVMk4U8Q
Let me know the codes and we can go from there. Thanks
Apr 9, 2020 at 11:20 AM
  • 55,797 POSTS
Here is a video we did on how to get he ABS and traction control codes yourself:
https://youtu.be/rTtAnsOlZU4
Apr 11, 2020 at 4:45 AM
CAVALIERDRIVER141
Hello again, this is Robert Butler regarding my traction control light staying on.My question to you is there a module, for the traction control light? A friend of mine Brian owns a Exxon station and there were no codes,for the traction control light.Thank you!
Apr 11, 2020 at 4:50 AM
I attached the information about this system. The fact that he found no codes is odd. As you can see in this description, the traction control light remaining on is indicating the system is disabled due to a DTC.
Were there any DTCs in the system? Any for the ABS system?
Apr 12, 2020 at 3:55 AM
