Will not shift into reverse
30 MILES • 1.4L • 4 CYL • 2WD • MANUAL
CELE
My Tata Indica 2008 model does not take reverse every time after driving on gear five, but if I am driving on gear four, reverse will be fine. today I was rushing to town and accidentally drove in gear five, I had to push the car after I have parked in order to reverse it and drive of the parking. it once locked all the gears one day except gear five after trying to change down from five in order to stop. help me.
Nov 29, 2017 at 2:45 AM
  • 31,937 POSTS
Sounds as if there is an internal problem with the selectors. first i would check the oil level and if it looks dirty and contaminated try an oil change, if that is not helping, make sure that the clutch is okay and failing. i feel that there will be an internal problem in the transmission and it will have to be removed and stripped for further inspection.
Nov 29, 2017 at 1:50 PM
