My SRS light is on, many codes
128,800 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
VIVEKHB
  • 93 POSTS
The scanner shows DTC as follows;
1. B102B
2. B102D
3. B106C
4. B107A
5. B107B
6. B1003
7. B1025
8. B1027
9. B1029
10. B1031
11. B1033
12. B1076
Sir, please help me to know exactly what is to be done/changed.
Aug 9, 2019 at 3:56 AM
  • 55,851 POSTS
It looks like the SAM module is out. To be sure lets clear the codes and then turn the key on without starting the engine to see which codes come up. Here are two guides to help us:
https://youtu.be/ahK_eucFi-k
and
https://youtu.be/HEvLsWdcL0M
Aug 10, 2019 at 7:13 AM
VIVEKHB
  • 93 POSTS
Thanks a lot ,Sir.I will let you know what's the output.
Aug 10, 2019 at 10:31 AM
  • 55,851 POSTS
Please do ;)
Aug 12, 2019 at 3:34 AM
VIVEKHB
  • 93 POSTS
Sure,I have to buy the OBD2 first, so please give me some time.
Aug 12, 2019 at 5:44 AM
  • 55,851 POSTS
I would try Amazon they have them between $20.00 and $300.00 Here is the one I would get. Here is one for 115.00
https://www.amazon.com/gp/product/B072XH9GLW/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=2carprcom-20&creative=9325&linkCode=as2&creativeASIN=B072XH9GLW&linkId=6bf2476ef5f43cd382a94aa4a6507ad4
Aug 13, 2019 at 2:18 AM
VIVEKHB
  • 93 POSTS
Thanks for the website.
Aug 13, 2019 at 7:44 AM
  • 55,851 POSTS
Aug 14, 2019 at 3:55 AM
VIVEKHB
  • 93 POSTS
Sir,after I tried but the codes could not be erased.The data stream shows as follows ,
Aug 17, 2019 at 9:59 AM
  • 55,851 POSTS
Okay, it looks like the CAN is not working due to the failure of the airbag control module. To be sure here are the airbag wiring diagrams so you can test for power and grounds with the airbag module replacement instructions:
Check out the diagrams (below). Please let us know what you find.
Aug 18, 2019 at 5:37 AM
