Reverse does not work
268,848 MILES • 8.0L • 6 CYL • 4WD • AUTOMATIC
JUSTBU
My gears all work but reverse does not. if I put it in reverse it wants to go but does not move.
Oct 13, 2019 at 10:26 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you just lost the reverse clutch pack. That will require the removal of the transmission and a complete rebuild. You might also want to see if your local auto wrecking yard might have a used one hopefully with a small warranty. Rebuilding your transmission is roughly $1,000.00 to $2,000.00 depending on your area/type of shop you go to. Hope this helps and thanks for using 2CarPros.
Danny-
Oct 13, 2019 at 11:08 AM
