My Radiator is Average Heating Up?
111,001 MILES
MICHAELLSJ
  • 27 POSTS
I Have to Put Coolant @ 1st?, then after a Long Simple Drive About 3-5 Miles distance driving it on a 35 MPH Zone. I had to refill water in the reservoir container. It's like where did I put the coolant & it's Gone.? I hear a gurgling from the upper hose like its having a hard time drinking the water? Where & How may solve this problem with your assistance? Thank you awaiting for your reply/response.
P.S.
I Already change the water pump & thermostat components.
Jul 19, 2013 at 10:45 PM
HMAC300
  • 48,601 POSTS
have apro pressure check your coolant system for leaks it may be ahead gasket
Jul 19, 2013 at 10:49 PM
MICHAELLSJ
  • 27 POSTS
The headgasket have already been change before I bought the car.
& on a Toyota corolla dx 16 valve efi automatic (4 cylinder) 1991, is there a block drain plug? The only plug I know is on the radiator that is mounted in/on the bottom tank?
Jul 19, 2013 at 11:15 PM
HMAC300
  • 48,601 POSTS
check radiator for cold spots or loose corroded fins if there are the rad needs replacing. also do what I've suggested I first reply.
Jul 20, 2013 at 12:33 AM
